I have noticed over the years that as I am climbing hill in the western states mountains that my engine output collapses with the increased hill climbing load. I finally decided that the problem was associated with the placement of the transmission cooler in front of the end stage of the engine inter-cooler. Thus as hills are encountered and the transmission generates more heat that in turn is ends up dumping more heat into the OEM oil cooler which then dumps the heat into the inter-cooler. The 12 valve Cummins diesel is very sensitive to intake air temperature. The engine output drops dramatically as the intake air temperature climbs. I went on the Internet to try and find out what the BTU rating of the OEM oil cooler was with no luck. So I decided that the best approach was to introduce a pre-cooler in front of the OEM transmission oil cooler. I welded up some brackets which allowed me to install a Setrab SLM592-10 33,000 to 46,000 BTU (with 60 mph airflow) oil cooler in the inner space behind the bumper below the OEM cooler. This has helped my engine output. However, the air flow is not optimal and I added supplemental fans to try and increase the flow of air through the cooler as a partial solution. I would like to just remove the OEM cooler but with no data on performance that’s not a great move.
Is there anyone out there who has worked the “OEM oil cooler problem” on the second generation Dodge and come up with a better solution for working this problem.
