When I dropped the valve body I did not take the park pull rod out with the valve body. So when I noticed the little spring and ball lying on top of the valve body, I investigated and notice in the manual that I was supposed to drop the valve body and rotate and then pull park rod out of the sprag.
So now in my attempt to pull it out of the sprag it will not come. It does move freely in and out but stops short of coming out. I have rotated it in all of the positions that I could have if it were still attached to the valve body, but no luck.
I know I shouldn't have to force it, so what is the trick? I have rotated the drive shaft some then tried, no luck.
Please help so I can get this back together to test it!
Thanks a lot!!
Steve
96 3500 4x4 automatic
