transmission probe
ON my 03 with 5 speed tran. it would not go into gear.
NEW Ring and Pinion for 2003-2006 Ram 2500 Front w/3.73 ratio?
Some time ago I purchased and installed a transmission line from Mass Diesel. It is now leaking at the rubber part of the line, I am thinking about replacing the line with my factory line and a Acu Temp Adapter from Genos garage. My question is has anyone else used this adapter and how is it working for you?
puller
I've used one for years. In my experience it does not pick up enough heat from the cooler line to provide an accurate temp read to the gauge. It's better than no gauge at all but its not very accurate.
Harvey, whats the variance with the acu temp and where is the best place to install it on an 06 ? Got any pics of location of yours. I am about to install one and i would like to have it where the hottest fluid is flowing
