Could be your overdrive fighting with your Throttle Position Sensor.
If this happens it will drop a gear and then jump right back very abruptly!
This is more pron to happen with the OverDrive "active". Try disengaging your OD at the same stretch of road and see if this prevents this from happening. If it does, then I'd say it was your OD and TPS battling it out. OD wins first round, TPS drops a gear suddenly in round two, and then the OD comes around to win round three.
Best solution is to know about when this happens and disengage your OD for that stretch of road, if possible, so the two dogs won't fight.
Mine used to do this just below the same mountain summit while the OD was active. The OD thought it could handle the hill and the TPS would suddenly (and violently) drop a gear. Then in a fraction of a second, the OD would take over again.
I haven't had a problem with the new transmission and power enhancements.
