Saturday 21st... ... . I spent a bunch of time under the truck today, new info posted after the replies that are already up. It doesn't sound like the transmission.
My truck has recently started making a lower pitched whine than what comes from the turbo. The sound can be heard in park if you have someone rev the engine up while I listen from under the truck (not very loud when in park and sitting inside truck), it seems to be coming from the automatic transmission. Definitely not coming from around the turbo area.
When driving it is much easier to hear than in park. The sound can be made to rise and fall with the throttle, can even make it sound like a siren!! It is most noticable at lower speeds, above 35 it is hard to tell if it is still there because of the road noise. It rises and falls with the rpms of the engine and can be heard under much lighter acceleration than what is needed before the higher pitched turbo is heard. The noise is noticable on the flat, doesn't need to be going up hill.
It has been around 30 at night and 45 in the daytime. The weather has been this temp off and on for a couple months but the noise only started recently. My drive to work is mostly downhill and takes about 25 mins, I can still hear the whine but it is much quieter than when I start the drive. The uphill trip going home warms everything up good and the noise is gone. The oil level in the transmission is where it should be.
I was told it sounds like the transmission pump and is nothing to worry about unless it gets much worse and doesn't go away when hot. Does that sound correct (sounds like a good diagnosis to me)? Any ideas on what it might be if not the transmission pump? Any others have the same sound?
Thank you for any info/advice.
