I took my truck in for the 1-2-1-2 shift problem. 58,000miles. The dealer says it needs rebuilding... 1st & 2nd clutch pacs are worn??? My trans towed great except under light acceleration(hunting between 1 & 2). Are they just soaking dodge??
I think he's talking about the 7yr/70k powertrain, which was still available on the '05...
this was worded a bit unclear.if you are mechanically inclined, like have the ability to drain oil and change a spark plug/oil filter etc. I would first adjust the front band. IIRC you need a 3/4" wrench and #30 torx. basically the torque settings have the torx screw just where it stops against the band. SO EASY.
Second would be to replace the governor solenoid and while there since you need the pan off, do a rear band adjustment.
If you have never had the bands adjusted before, it may be too late though. If not done at 30k they can shell the transmission
