is this true? the fluid leaves the transmission and goes thru radiator and then cooler and then another cooler alongside pas. side of engine and then back into transmission. well while plowing snow in a confined area, not much air movement, my transmission temp will rise to the top which is 250* and bounce there. i then let her cool down . i have plowed snow for 30yrs and never had a transmission guage and no transmission problems. knock-knock. should i put larger cooler on her? the guage seems to be working alright, did ck sender wire. its good. any input would be a help ! tnx
