John, When I added my temp gage back in 2009 there was not a lot of options that I could fine. I also wanted to run extra fluid the trans plus the option of having an AL fin cover sounded good to me. So, I installed a MAG-Hytec AL deep dish transmission pan which added 3 qts of fluid. The pan has a magnetic drain plug and a rear port for a temp probe.Did your pan come with a port for a sensor? Or did you use one of the add on kits that threads on like an add a drain kit?
The drain plug makes for easier servicing to allow most of the fluid to be removed before dropping the pan to change both filters.
