A while ago I asked a couple of questions regarding getting my transmission serviced. The one common answer seemed to be to undertake the service myself and not to trust it to a Jiffy Lube. Well I am about to undertake that task and would like to ask some questions to get some confidence. I know most of these have been asked at various times but I have forgotten most of the answers. I would appreciate getting the answers all at once. My truck is a 2001 2500,4x4,4:10, Auto. No upgrades but guages. My questions are:
1. I have 15,000 miles on it. Approx. 25% towing
a fifth wheel trailer weighing about 9000#
wet weight.
(a) Is dropping the pan and changing the filter
sufficient for it. If so how much fluid
does it take ?
(B) Some I have read disconnect a line and
drain more of the fluid. Is that necessary?
If so how much fluid does that take?
(c) The manual for the 2001 calls for ATF-4 but
some have suggested using the ATF-3 because
there is less slippage with the 3. Would
this be recommended or not?
2. I understand the manual calls for a band
adjustment with every service. Is that necess-
ary. If that is so that would keep me from doing
my own service. I dont think I would attempt
it if thats the case. If I do the normal
service,I have been told that it could
jeopardize my warranty. Could that be so?
3. I sent for a Mopar filter from Geno's, but I
have read also on the TDR that some recommend
a different kind. Is that so? and If yes where
do you get one?
4. What is the torque on the pan bolts.
5. And finally any other suggestions are apprec-
iated. I hope I did not ask too many questions
at once.
Thanks
John
wet weight.
does it take ?
do you get one?
at once.
Thanks
John
