Transmission Shift Points
Lift Pump
Lost 5th gear
I have a 98 3500 12V Auto. I would like to raise the shift points. The trans shifts from first to second at about 10MPH, and sec to third at about 20MPH. Is there any way I can raise the shift points?
Thanks
Chuck
Chuck, they are actually easy to do you just have to drop the pan to do it, E-mail me and I will try to walk you through it... it's not bad! -- email address removed -- or 405-387-3924(H)
If someone has a pic of a valve body on the drivers side would you post it so I can explain how do make this adjustment, guess I should have made some measurements with the pan off.
Jim
