I'm starting to get dizzy from information overload and comparison making. I just want the best build or in the case with the local shop, "rebuild" I can get for the money. I feel certain that BD would provide an excellent Stage-1 (single disk TC though) and no billet flex plate? I think. Also their 3yr. 150k warranty sounds good where the locals are only 24m. 12k. but BD's costing $1000. more than the local shop totaling over $6500. 00 I'd really like to keep my money in the US and more specifically, local. (However, Oregon with no sales tax is also appealing as funds are limited)
Here is what I was quoted using a comparison of HD parts from Goerend by a local shop. (one mentioned here)
"All shiftworks heavy duty transmission include, all new gasket seals, clutches, bushings,fliter, bearings,low one way clutch, over drive one-way clutch, solenoids and sensors, overdrive direct clutch snap ring, direct clutch snap ring, heavy duty band strut, pro series front band, rear band, re programed valve body, re-manufactured pump with added clutch plate to the direct and over drive clutch packs, the price for the above is $2995. 00
A triple disk billet converter is $1295. 00
Labor to remove are re place is $622. 51
Fluid to fill transmission is $80. 00 (I will provide my own Amsoil)
A billet input shaft is available for $695. 00
It is made by TCS Products if you need more information on it you can look it up on there website the part # is 129600L
Price without input shaft is $4992. 51 plus tax
Price with input shaft is $5687. 51 plus tax
I will do whole job without input shaft for $4500. 00 or with input shaft for $5195. 00 plus tax. "
It seems if I recall, the builder at BD was more detailed in what was provided with regard to performance enhancements. Drilling something out ? Also, an external filter installed. . I just know I need to get this thing done and soon. Anymore input would be much appreciated.
