When I go around a corner at regular speed(such as turning on city blocks 90 degree turns)and hold the throttle steady, the transmission shifts to 2nd gear(auto) then sort of slips or hunts for a position then is ok on the rest of the shifts. But if I,m going straight and accelerating slow it will sometimes do it. If I accelerate hard it does not do it at all. My transmission fluid level is OK I think and in good condition. What could this be a TPS going bad? I only have this problem mostly after filter and fluid change and if I add more fluid it seems to help a little but then I,m way overfull on the dipstick in neutral ,level and hot. I need input. Its really bad when the fluid level is right on the top mark where it should be. I wish it was easier to get the fluid level just right. Poor way to do it IMO HELP Thanks
99-24V-2500-Laramie-SLT-A/T-LSD-355
All Options except cab lights and carpet-Rino- Prime-Loc-Alcoa wheels-Lund cold front-Factory Tows-DSG Electronic Fast Idle-Mag-Hytec transmission Pan+Rear Diff. Cover -Tekonsha Voyager- VA CPC -Rancho 9000-5000 steering stabalizer - BD exhaust brake - Auto-loc - Astroflex autostart -Bill K. T/C and V/B in tranmission -Prime-Loc removed and hanging in garage-Alaska
