Originally posted by jqram35
Am I the only one whos truck takes several seconds to shift into OD when under light load or part throttle? Are there any reflashes to fix this issue? Thanks in advance.
Originally posted by jthorpe
I hate to say this to ya'all, but my trans. does not do this at all. It shifts the same no matter the temp. Whether it's 15 degrees or 80 degrees, it shifts fine. I would get it checked.
Maybe a stuck govorner solenoid? Maybe a VB problem? I also understand that there is some kind of seal problem in the 47RE that can cause this.
Jack
