Hi all, I know I have seen the answer to this but it escapes me! This started about 6 mths ago. If I have light pressure on the accelerator the trans slips between 3839 to 44-45mph. If I put pressure on it to get it going it will mostly cruise right through the issue or if I turn the O. D. off, it will not do the slipping/stuttering (though it did happen once with the OD off. )
Truck as around 185k on it, regular maintenance done on it. I am seriously hoping it is not the TC or Trans.
2001 dodge ram diesel, auto(47RE??), 8' bed, quad cab, stock, 4x2
I read some where I could do the disconnect the batteries, press the gas pedal, reconnect the batteries and that will solve issue?? Has anyone here had to use this process and if so, did it work for you?
Thanks in advance for your assistance and time!
Tony.
Tony.
