Engine/Transmission (1994 - 1998) transmission sudden loss of drive
Engine/Transmission (1994 - 1998) #4 Plate Installed
Engine/Transmission (1998.5 - 2002) heavy smoke twice at takeoff.
i was driving at 60 on the freeway when the transmission suddenly lost drive. . any thoughts on what may have gone wrong. .
symptoms no forward or reverse
as if it shifted into neutral
drive shaft doesnt rotate when i put it into gear
no noises
just a sudden shift to neutral
90,000 miles
1997 diesel automatic
running amsoil synthetic
fluid still clean . . no smell
Check the simple things first.
Check the ATF level in the trans, make sure you didn't break a line and dump the fluid on the freeway.
Then, make sure the shift lever is moving the linkage on the trans. Do you still feel the detents for the lever positions??
If you put the shift lever in Park, is it in Park?? IF not, check to see that the Transfer case is not in neutral assuming it is a 4x4.
If it is full of ATF, still goes into park when selected, and the ATF is clean, It sounds like the input shaft is broken.
Hope this helps, Greg L
i had this happen to me only i was getting on the highway. it was like it went to nuetral. turned out that the torque convertor went and needless to say i needed not only a new tq conv. but a rebuild on the whole transmission due to metal shavings.
