I am planning on installing a 47rh transmission in my 1992 CTD. I have read all the previous posts concerning this and am now rounding up my parts.
Now I have a question for you transmission gurus. I have access to two 1995 transmissions. One is from a two wheel 2500 but the main case is cracked beyond repair but the overdrive section is still good. The other is from a 1995 four wheel drive. I am assuming,dangerous as it is, that the overdrive assembly from the two wheel drive transmission will bolt up properly to the four wheel drive main transmission. In other words, I am thinking that the overdrive sections are the only differences in these complete transmissions, and that the main section is identical in both transmissions. I need to know this before buying them and then finding out that there are some differences in the main transmissions, such as in output shafts, etc. .
Thanks in advance for any info on this! I know that for many of you this is probably a simple question but I am not at all familiar with these transmissions.
When I get this project done I will report back with the results. All the other parts I will need have been located and I look forward to making this swap.
Just realized that this probably should have been put in the First Gen Forum. Please move it if needed. Sorry about that and THANKS!
