I installed a Perma-Cool remote transmission filter and temperature gauge today and the temp gauge shows about 210 degrees when the truck is idling in drive and when i go down the highway it stays pretty close to the same. Is this normal or is the gauge setup not accurate enough? This is all with the truck empty and towing nothing and with it 83 degrees outside. I thought it would cool down more on the hiway? The only reason i got it was to keep an eye on the temp when i am towing 29' alumalite at 5500 lb. full. I haven't towed it yet with the gauge installed and now i am paranoid since i have seen the temp. Is this a normal temp? What is to high if i am towing?
