Issue: Transmission sputtering at 55 to 60 mph. Torque converter locking and unlocking while driving. weird part when depressing throttle to floor engine did not rev up this was while moving on highway. When I moved transmission to neutral while rolling and depressed throttle to floor the engine would rev up .
About three years ago I replaced the two little adjust bits that that secure second gear and first gears. I knew I was on borrowed time so to make it three years is pretty good.
Just limped home at 15 mph. seems like I only have 1st or 2nd gear. Once home, praise the Lord, I checked transmission dipstick, fluid fine, no burn smell.
I do not have a code check device available.
Does this issue seem like a sensor or electronic issue given that when transmission is in gear and when I press throttle to floor it does not rev beyond the rpm's its currently at. where should I check first?
Please advise.
Preparing to order a Suncoast torque converter and trans rebuild kit.
any help is appreciated.
Please advise.
