New valve bodies are over $400 I am told. Isn't the so-called shift kit really a reworking of the old valve body? What will a new one do that the old one reworked not do? This relates to my '95 that is in shop for rebuild.
But a new t. c. is clearly required, just wondering about valve bodies.
And as a very immportant reminder, these transmissions give very erroneous fluid level readings in PARK. They must only be check in NEUTRAL. Also, use back side of dipstick for accurate level as the front side gets wiped. I had serious shifting problems for many miles due to misreading dipstick. This warning has been on the forum and needs repeating regularly.
thks
