Should I buy a new transmission or buy a new T/Q with V/B upgrade? I got a quote with labor for the TQ & V/B for $3,000 ( Suncoast). I did not get a quote for the whole new transmission, but I figure add another $3,000. Thanks.
I just wrecked my 2005 7 days after having the transmission built with a Suncoast 3disk TC and dbl sided flex plate, transgo kit / X-treme red alto / kolene steels,... has 3yr unlimited miles / tow weight warranty if interested PM me, or direct email tomconnolly at gophertortoise dot org. Also have intact the Laramie Quad cab med slate, nav radio/ 5. 9L Cummins / Manual transfer case / 3:73 front and SRW / accident took out L ft and rear quarters driver door and bent frame Repairs will take 2 months and I need to work so I replacing with 2007 6. 7L 6spd auto. Not a scratch on me! Was hit by a F150 both trucks moving 40mph they were'nt as lucky.
my mom got ****** off at me when she brought my truck home after hitting a deer. cuz when I saw the damage she did to my truck about 140 miles from where she was supposed to be with my truck and hit a deer I knew the truck was safe and I knew she wasn't hurt. So the first thing I said was the truck and not her and she was fired up. But she wasn't where she was supposed to be, hit a deer tip toeing across the highway cuz she wasn't paying attention (playing with the sirus radio trying to find a station) looked up and there it was right there in the middle of the 8 lane highway. I knew she couldn't pay for it and she didn't have insurance either. All my money was being spent on performance and I didn't have money for non functional crap. the crappy thing about it was she told my sister and neither she or my sister would tell me what happened. Do you wanna tell me who told me what happened? When she got home with my truck it was dark out and I couldn't see but the great dane started sniffing it really hard for about 10 minutes even crawling underneath it so I got the flashlight and I blew up. lesson learned no matter how safe you know you truck is and the conditions of the incident always say are you ok and then after that is said its ok to start throwing a fit.
SORRY i hijacked your post above but as to the answer to your question about you trans: I have a 2004. 5 I had banks 6 gun with speedloader on it. when the 6 gun with speedloader worked I had a top speed of 70mph at wide open throttle. This was cuz I was slipping either the torque converter or the Overdrive unit on the transmission. AT the time I had that setup I went to the dealer and had them look at slippage when the automatic transmission (48RE in dodges 2003-2007. 5) when 4th gear was applied. I took the tech for a wild ride he noticed slippage and we talked about it. then a few days later I went to pick it up and he claimed nothing was slipping when the entire time the banks was picking up on it and going back to stock power levels. I finally destroyed the 48re when I added more power, had a expensive long distance tow bill and here the transmission sits next to me in my kitchen waiting on parts. I have found my problems I have been having the entire time, so heres all you have to do if you will run 6 gun with speedloader or even a big hoss kit but only tow a boat and drive unloaded with no abuse from competition sled pulling or drag racing with more power than the banks stuff can provide:
Overdrive unit needs to be upgraded with better quality clutches and replace the big like 3inch (cant find in the pile of parts) roller bearing that is located in the the overdrive housing. this roller bearing is notorious for going bad and making alot of noise. Lets see thats pretty much all that the OD part of the trans will need but I reccomend you having a company other than ATS or PATC do this for you as I am dealing with them right now on parts!@#$%^&*() = see below for additional details. you also have to have a aftermarket torque converter and valve body for your useage of the truck. Don't let anyone talk you into changing the input shaft, intermeddiate, or output shafts. FOR YOUR CURRENT USEAGE YOU DO NOT require these expensive items. I personally have put a serious beating on my truck 4 wheeling, stood the truck on it back wheels (2004. 5 QC Long bed DRW), pulled 8,000lbs frequently, used it for sled pulling and drag racing (illegally), burnout competitions, back to back pulling, and also the truck seems to always have the accellerator pedal to the floor where ever I go. Upon disassembly of my stock 48re I have found that all the shafts and other hard parts are in ready race condition other than they are not strong enough for the power I will be building this year.
SO recap torque converter (I will sell you the brand new in box banks I bought 6 month ago as I have decided i will be building above 1200 lbft of torque so cannot using banks must run ATS)
valve body (buy complete beginners need not mess with)
Overdrive unit needs new roller bearing regardless of mileage and upgraded clutches
also remember to adjust rear band at time of valve body replacement. rear band is used for reverse.
Also I suggest adjusting the front band every 15,000 miles if you want to make it last longer than no maintenance. The front band is adjust without dropping the transmission pan. there is adjuster located above the shift linkage mounted on the drivers side of the transmission near one of the transmission lines. procedure is back off nut then run the threaded rod like piece in and torque to 72 in lbs (keyword inch lbs, not ftlbs) then back off 1 and 3/4 rounds tighten jamb nut. as the band wears you are compensating by adjusting for the wear.
!@#$%^&*() = ATS took 1 week with their head up their butt before they decided to ship the parts I have not yet recieved. PATC lists parts on their website for one application dodge but when I recieve it it turns out to be another application (happened with many of the parts in the 2 different orders from them) also they have been opening up clutches and packaging the with the steels that have oil from the machining process still on them so I have been recieving contaminated clutches that all I can do is throw in the trash. not to mention the one clutch that had a manufacturing defect that had to be thrown away.
