Block the wheels so truck can't roll as the rod that engages the park pawl is connected to the valve body and can be dislodged when removing the valve body. Also I would clean off as best you can the part of the valve body that sticks up through the side of the transmission so dirt/etc won't be pulled down through the oil seal, especially if you are going to reuse the seal. bg
