93D250 4x4... intercooled 4spd at,125,000 ,miles.
overdrive has a hard time shifting in and also wants to shift down at lower speeds,40 or so. this seems to be temperature related as it is worse when its cold out and it seems to stop when the temps outdoors is say, 60 or above or the truck has been on the road for awhile (a good while i might ad)! when it is cold i have to feather the acel or simply just PUT FOOT IN IT ! it has the cooler in front of the rad and it has and additional cooler under truck with an elec fan. the oil has been changed (oil and filter from dodge) and the filter was clean as a pin! one more thing,if this machine sets for awhile it also has a symptom of when transmision is first enguaged it takes a few seconds for the clutches to grab, as stated before... temperature related also !
does anyone have any suggestions ?
