I want to start by saying I have learned a lot from reading over these forums since I got my truck last summer and thanks to all of you for passing along then info! I drive a bone stock 2006 2500 4wd QC with the 48re. Up until buying this truck I have always shifted my own gears, but with all the stop and go I do now wanted an auto. My question is this and it may sound stupid to some of yall but here it goes... . When an auto transmission "goes out" on you, what is it that normally fails? I'm not talking about busting the input shaft with 1200lbs of torque, but what is the part that fails behind a stock engine under normal circumstances? Is it bearings, converter... . ?
Next question... . If I keep my truck within 50hp of stock or even bone stock, would I realize much from a more high performance converter? And if I keep everthing on the engine stock would there be anything that I should add at the time if I were to get a better converter installed?
