transmission ?
Advice On A Clutch
Any Ideas on all these Fault codes?
Only on a cold start(doesnt matter what the outside temp is) I drive carefully til she is warmed up,the transmission shifts through the gears but gets to od and it shifts then slips a bit then locks up?Does this sound right?I know my ford used to not lock up the tc when the engine was cold,is this the same type deal?Other than that and the 12211221 shift bs the transmission shifts fine.
Dumb ? but if I go to the dealer to have this done under warranty are they going to know about the TSB or will they play dumb,well not play but just be dumb?
I had to give my dealer the TSB # so he could find it. TDR is a great source of information, many times information dealers have no clue on, until you give it to them.
