Details here: TDR Privileges
The governor is different. The V10 governor may act goofy behind a diesel. It takes a little bit of work to replace the weight with the one in the diesel trans because it is inside the tail shaft.
That would work. It has the OD in it. Everything is the same except the governor weights so the tail shaft from the diesel will bolt right up to it. The only hard part is the park rod.
