My wife hit the brakes yesterday to avoid someone who pull in front of her, and the check engine light came on after a wizzing sound. The trouble code is P1693
The are two decription in the Dodge manual
DTC Detected in Compansion Module, A fault has been generated in the companion engine manual contol module
DTC Detected in PCM/ECM or DTC Detected in the ECM, A"companion DTC" was set in both the ECM and PCM
Can any one tell me what this means, the power appears to be only down slightly,
Recent change include installing RV275, a comp on level 1x2, and turn buckle.
I am traveling and away for a while, doe anyone know of a good place non dealer to take the truck near Portland if it needs work.
thanks joe
thanks joe
