I have replaced my oil sender unit a month ago, the new unit started acting up last week as I posted here. Today it threw the check gauges light and oil pressure dropped several times and then recovered to about 30psi. Not good.
Then a couple blocks from home I heard a loud BARK from under the hood. Happened several times. Was able to get it home and in the garage.
The turbo is shot and the bearings are crap. I had this stock LM25S Holset turbo rebuilt several years ago. My son and I now think I have a oil blockage and/or bad oil pump and that killed my turbo. Just look at the factory service manual and I'm glad to see that the oil pump is not in the oil pan but front of block. I can handle it there if need be.
Will something blocking the oil pickup in the pan cause failure? Trying to figure it out how to check the oil pickup?
Also I need advice about after market mild upgrade turbo. not trying to go crazy, just better spooling I've read about in the past.
I think I'm in shock and I don't know what to do first this time. I need some advice from someone with similar experience.
Thanks in advance,:{:{:{
Tom
Tom
