A few days ago in the parking lot at work, turned the ignition on for the radio, then back off. A couple minutes later started the truck, idles normal, in park and in gear, touch accelerator and it's bucking and jerking. pull over check under hood,(nothing obvious) drain fuel filter, (nothing) start it up, all good drive home. For five or six drive cycles, purring like a kitten. On my way to work, throw a MIL. Finally am able to get a DTC of p0226b, After that code pull, start the engine, same symptoms as before, except at idle also. Turn it off wait a couple minutes drive home normal. I've searched our database but can't seem to get a confirmation on what the problem is. or the DTC. thanks for reading the long explanation.
Bone stock, 28,400 miles
Fuel filter has 7K on it.
OAT is in the 70's
OAT is in the 70's
