I bought our 28" toyhauler last fall and when I drove it home I noticed the brakes were barely working. I found the 7 pin plug had alot of corrosion and when I replaced it I also found 2 broken wires which explained the intermittent light operation. I then pulled the brakes to inspect them and found that the previous owner was over zealous when greasing the bearing buddies so there was grease on all the brakes so I replaced the brakes, installed new seals and repacked all the wheel bearings and adjusted the brakes. (The axles are made by Dexter)
I hooked up to the trailer to take it for a test drive and verified the brake lights work but when I'm driving it the brakes still don't feel like they are working very well. I increased the gain on the brake controller and it made no difference. I don't get the red light on the Hayes brake controller when the foot brake is applied but it does come on when I manually apply the brake switch on the brake controller. When I manually apply the brakes switch on the brake controller I can feel the brakes work but it's weak at best.
What's the best way to troubleshoot the electric brake system on my trailer?
Thanks in advance,
Patrick
Thanks in advance,
Patrick
