2nd Gen Non-Engine/Transmission Troubleshooting transmission temp gauge?
2nd Gen Non-Engine/Transmission Cheap stack ideas?!
I have a Westach 300 degree gauge with the probe in a Maghytech transmission pan. It has worked fine but now upon accelleration it drops to zero but at idle it works fine. Is this a gauge problem ,probe problem or bad connection in the wiring. Please give me your best guess. Thanks
Check the grounds. All gauges like the ground wire attached close to were the sensor (probe) is located and not run thru the body, frame or moror/transmission.
