Got off work tonite 27 deg. out. I figured grids would cycle for a while, but the light only stayed on for about 3-5 sec. I thought that was weid so I waited about a nother 2-3 sec. then figured Id start and see what happens. It started but barely it was sluggish for about 5 sec. than I manually brought the R's up to about 1200-1400 and let it run for a while. I cranked the heater full blast while I was waiting and it would blow real hard then cut back, then real hard (blow) then soft again. It fluctuated with the engine RPM's (simultaneously) I dont know if that is the AC cycling or what??? Any ideas or is there not anything to worry about??? Thanks guys!!!
