I'm new to this. I need some help from you guys! I have a 01 24valve completely stock 5spd, 93,000 mi on it. When I start it sometimes no matter if it is cold out or hot my truck will idle fine but I go to pull out it will seem like it's sluggish and hesitate. If I stop and shut it off and start it again it will run fine! 2nd problem I'll be running down the highway about 70 to 75 and the truck will start losing speed down to about 52 to about 55 and the RPM wont go over 1700 if I go to the side and slow down and come to a stop or go to the side of the road and shut it down and start it again it will run fine. I had it to the dealer and they changed the fuel transfer pump Is that also called the lift pump. after they changed it it ran fine for a day then started it again. dealer says cant find no problem with it. also I get about 14mpg. if anyone has suggestions or can help would be great.
