Engine/Transmission (1998.5 - 2002) Truck bogs down
Engine/Transmission (1994 - 1998) 03 for 29k
Out of the blue going down the road hammer down and nothig wait till it came to an idle and got power again
who Knows that site where to find the definitions for the codes?
I got,
P PCU
P 1693
P Done
P ECU
P 0523
P 0121
P Done
I did try to reduce the idle earlier this afternoon by turning back the torx screw where the throdle body is. Dont know if this had anything to do with it, it was idling at 975 my other rig idles at about 7/ 750 they are both six spd
CAN ANYONE HELP?
P0523 - Oil Pressure Sending Unit Voltage too high
P0121 - APPS signal voltage too low
P1693 - Code set in companion module (always show up whenever you get another code)
The P0121 will trigger the Check Engine light. Looks like your APPS might be flaking out.
If you can, I'd reset the throttle stop you screwed with. Aparrently your truck doesn't like it. It's probably sending the wrong signal all over the system.
