Details here: TDR Privileges
I’ve seen some trucks that have optional under the box rail lights. My 2015 2500 does not. Would anyone know if the wiring is there or will I have to run it to the cab upfitter switches? Thank you
The OEM bed lighting is two LED’s back by the tailgate. Prior to 2018 there was only a switch in the cab to activate it.
The kit I bought for my 2018 had the required wiring to run up to the PCM for power, but my truck was pre-wired so all I had to do was plug the lights in and have Ram activate the sales code for the lights. You may have to do the same on a 2015, or use AlfaOBD.
