I was getting some lunch and when i came to a stop light my truck sounded really weird... It sounded like an exhaust brake was closing up my exhaust and the truck wanted to pull me through the light... So i put it in neutral and the rpms jumped up a couple hundered rpms and returned to normal... Then when I put it back in drive it stalled right away... So i restarted it & put it in drive again and had to give it fuel so it wouldn't stall. . then when i got going it sounded like the engine had a load on it... Once I got going it shifted fine & ran fine until I got to the parking lot and pulled into my spot where it did the exact same thing and my pyro was going up to around 600 and my boost was up around 5lbs and the engine sounded like it had a load on it so i took it out of gear and shut it off and found no codes set... What could be causing this? Could the wastegate closing cause something like that to happen? And is it safe to drive it like that?
