Archived Truck Clunking and chunking when coming to a stop
Archived Need help-Bent Two Rims and Blew 2 Tires Today
Archived brake problem
Hello,
I just bought an 03 Dodge 3500 DRW 6spd, has 50k on it. Drove it 900 miles home and noticed the following day that when I am coming to a stop with or without the brakes in neutral with the clutch not depressed it clunks and shutters from around 15mph to 5mph. I do not notice it upon takeoff or when driving at any other speed. Only when slowing down... It will also do the same thing if I am in gear, again only when slowing down and in between these speeds. It is under the powertrain warranty so I believe I will take it in, Just wondering what you guys thought this might be.
I climbed underneath and it does not appear to be leaking anywhere nor does it have ant signs of previous wetness.
Thanks for your input.
JJ Pudenz
Yes visually they look great, I tried to move them around and the whole driveline turns without issue... I am not really sure what to look for other than obvious slop.
JJ
Mine used to d othat because of rear brakes. Even though yours has discs in the rear they could be the culprit - rotors out of round a tad. Try this - in neutral, no clutch, no brakes - apply slight pressure to the emergency brake - if problem happens look at rear brakes. Sorry I'm not sure if the rear disc set up has separate pads for emergency brake or not?
