Just finished pulling the antenna coax through the firewall grommet and installing the connector. Tried to start the truck and it acted like the clutch safety switch wasnt activated. All lights ,radio, etc worked fine. Volt meter stays on 12 V will trying to start, and with the headlights and driving lights on it still stays on 12V so I believe the battery is OK it seems like the signal from the Ign switch to the starter isnt getting there.
Anybody have any good ideas? I also switched relays in the power center and it didnt help. Also disconnected the clutch safety switch and jumpered around it, no change.
TIA
John
TIA
John
