Archived Truck Dead
Archived eng check light on
Archived help FORD
Drove into the garage tonight and the truck died and the gauges all went dead. I have inside cab lights and headlights, but no gauges and no start. I am in the process of checking fuses, but so far none bad. Any thoughts or insights would be greatly appreciated.
Jim
I had the same thing happpen to me. There is a plug under the steering column cover that pulled loose when I raised the tilt steering to the upper limits. It kills everything that the steering wheel and column controls. It sounds like this could be your problem.
I always start by checking battery voltage with DVOM. Some computer systems shut down below x voltage.
But what they said sounds good.
Try placing the tilt steering wheel in the middle position and see if it works again. Mine did this for about a month until I had the time to pull the piece of black plastic under the steering wheel and fix the wire ends. There is a plug under there that has about 7 wires going into and out of it. 4 of them were either corroded or broken on mine:eek: I redid almost all of them. Works great now!:) :D :p
jandu and rrausch,
THANK YOU!!!!! I put the wheel down and it worked!! Now tomorrow I will take off the covers and see what is the problem with the wires. Thank you all for your replies and helping me find the problem, I will certainly sleep better tonight :D
It sure is great to have all this knowledge here and people with the willingness to share it and help others! Hopefully I can help you guys some day! :cool:
illflem, are we cursed with fusable links in our trucks?? Never did like those things... :rolleyes:
WadePatton, I'm with you, that was one of the first things I did.
Thanks again,
Jim
When you pull it, it will probably be the red wire. It's a 12 guage, I think, I just lengthened it with about 6 inches of similar wire. There is a thin plastic "lock" on the plug. Pull the lock out and you can get to the female ends of the wires and remove them. It's a pretty easy job. Let us know how it goes!
