Engine/Transmission (1998.5 - 2002) Truck died, how to test VP 44?
Engine/Transmission (1994 - 1998) starts......then dies
My truck died while driving about 50mph with no load. It may have run out of fuel but gauge read 1/4 tank. Pulled it home only 1 mile. Got fuel spray from main line going into VP44. Lift pump seems ok(Raptor pump) Fuel pressure gauge has been not functioning for couple months. Could not trust it. Cracked lines 3 and 4 no fuel to injectors. Is there a way to bypass the ecm to make the truck start. I know Cummins has a little box you plug in to bypass the electronics somehow. I just want to test the VP44 to see if it is bad or if it in the ecm . Thanks ahead for any help
Just a quick follow up. It turns out I simply ran out of fuel and my sender is bad in the tank. The guys at blue chip were great and gave me a couple tricks for purging out the air from the system. They could have just sold me a pump but they tried to help me. So I am giving them a big time plug for helping me.
I ran out the other day the only way I could get it to. Prime buy filling the filter while the pump was running and it finally picked up fule
Good to hear about Bluechip. They have helped me in the past, but haven'y had to call them foe awhile[knock on wood].
