Archived Truck Died
Archived headlight problem
Archived Lost power
i was driving down a hill and it hecuped like i bliped the throttle and when i pushed the go pedel there was nothing, pushed in the clutch and the truck just died. tried the smarty to scan for codes it would'nt connect, cycled the key and it said no bus. the asd relay is buzzing. i checked all fuses they look fine. swaped relays and still the same. please any thing to look for.
What's the fuel pressure? Sounds like no fuel. Is the FASS working properly?
I had a similar experience with my truck and it was the fuel shut off solenoid. Not sure on your pump, but it must have some fuel shutoff of some sort that could be causing the problem. Just a thought.
the fp does not run, with the no bus in the odom. i think either the pcm or ecm is dead?just really dont want to take it to a dealer but may have to.
