First, I'll give a little history and then I'll list the issues when I got it to stay running. I replaced the fuel filter myself for the first time on my 07 C&C and have @ 1000 miles on the new filter. I never had an issue nor do I show any sign of a diesel leak during that time period. Even though I don't relate it to my issue, I had the 220 amp alternator recall just performed and have a couple of hundred miles on it. Also the truck can sit for a couple of weeks with out running at a time.
Last week I started the truck and it died twice, before it stayed running. I had a check engine light, but my code reader is showing zero codes stored or otherwise, (I don't trust it) and after a couple of times of restarting the truck the CEL went away. I thought I might of had a seal failure with my fuel filter canister and was looking for signs of diesel leaks on my drive way, and saw none. Yesterday I started the truck and the battery was low in voltage, because I have a 12volt X 10 watt Crank Case Heater installed on my AC compressor. The CCH is only turned on 12 hrs before starting the truck, if it sits longer than two days. So with 11.5 vdc showing on my break smart LCD, I turned the ignition on and the grid heater light was on and voltage dropped to 10 vdc. When the light went out and the voltage returned to 11.5 vdc, I started the engine and it died, then restarted the engine, and it died again. On the third attempt, it did not have enough voltage to turn it over, so I got out my battery boost pack and started it and it ran normal on the first attempt afterwards. However on my way to work my TPS light was illuminated along with the CEL without any issues. I looked up in the owners manual what the TPS light meant, and it was OK to drive as long as it was not blinking, but I should see a dealer to check issue. When I restarted the truck after work, it started without issue and the TPS light was no longer illuminated but as I figured the CEL was still on because the ignition had not cycled enough yet.
Any opinion welcomed, I still suspect the fuel filter canister seal, and that the TPS was due to low voltage.
