I'm hoping that someone close will read this and just happen to have a Fleetgaurd FS-1023 Water Separator handy or know where I can pick one up locally on a Sunday.
No Fuel Pressure! Had the truck towed to our RV Park. We have to be out by 1/1/14!
Fuel Supply is a FASS with Filter and Water separator.
First thing I did was change the Fuel Filter but no help
I've verified that the pump is running
Pulled the Water Separator and it looked pretty bad. Tried cleaning it but no help.
Looked everywhere for a replacement Water Separator but can't find one that's an exact match (Fleetgaurd FS-1023) Which is a 144 Micron Filter.
Found a 10 Micron and installed it. Pressure came back to 12 PSI at idle but... once I get it on the road and run through the gears the pressure slowly drops to 0. Let idle and it slowly comes back to 11-12. I'm thinking the 10 micron W/S Filter is too restrictive and can't pull enough fuel to keep up with the engine demand.
Does anyone know if you can put a 10 micro W/S filter on the FASS pump???
