Question,
Thursday in Alabama the morning temperature got down to 2 above zero. I purposely let the truck set out over night and it had not run in the past two days. I wanted to see how the diesel would crank at this low temperature. Here are the details: 1 no block heater was used. 2. Shell 15-40 oil 3. only cycled grid heater one time. 4. Number 2 diesel 5. Shell DFA added to fuel about 100 miles ago before cold weather set in 6. Green lights was on on both batteries. The truck would crank stumble and then stall. I tried again cycled the heaters twice cranked stumbled and stalled again. By this time I was worried, let the truck set for couple of minutes cycled heaters twice again,cranked and it started and continued to stumbled but i held the starter motor in and when I released the key it stalled again. After about two more tries like this it fired off and ran flawless the rest of the day, and had normal power from the minute it cranked, so I don't think I had gelled fuel. Is this normal or do I have problems. Oh by the way I checked the lift pump pressure about three months ago 18-20 psi at idle, have not checked at wot.
