Help, Please.
Ok here is the deal. truck started vibrating in 5th at highway speeds light to no throttle, cold trany squeek until the end of the street. pulled it 5th gear ate in to the smooth part of the shaft just like quad 4x4 pics. couldn't aford there kit but did buy some small parts and tools from them. transmission seems to be fixed, I am primarily a gas motor mechanic but can go through a trans if I have to. ended up at 3. 5 thou of end play, should be ok.
now the "new" problem. decided to have the clutch rebuilt by the same guy that built it last time. Asheville Cluth and Brake, love his work I have put in many of his cluthes from toyotas to 5 ton military trucks, never had a problem. I have been making 30+ pounds of boost for about half of the two years and 65,000 miles I have put on the truck. the clutch had 65 thou of wear and looked grooved, but it held. every once in a while on a cold day it seemed to slip just a littlein the morning untill everything warmed up. Now it won't hold 8 lbs of boost. the clutch guy says that I make to much power. ck profile for minor mods, i am not making that much power. I had ten carbon metalic plus shaped pucks on it and now he wants to go cerametalic with ten pucks on the pressure plate side and go with a wider friction surface on the pressure plate. Any assistance would be greatly appreciated. I have spent my allowance and need truck back on the road.
thanks in advance
thanks in advance
