Archived truck down need fuel washer!!!
Archived '97 Fuel Pump Problem
Archived Lift pump cracked around flange
Refer to pic,
I need two of the rubber washers seen in the pic. The bolt is out of the injection pump were it gets pumped to the injs. I do know that the regular smaller rubber washers don't fit "from wildcat banjos"
I need them yesterday, i would like to get them before Monday i need the truck ASAP. will pay if you can get them to me quick.
I called everywere and the soonest i can get them is Mon.
Knowbody around here doesn't have anything.
Did you try to reuse them yet? If you haven't, they can sometimes be reused without any leaks. I haven't had to replace ANY washers that I have removed doing repairs/BOMBing.
Do you have aftermarket banjo bolts that are bigger that the OEM ones don't fit?
Give me your address and I have a set that came with the banjo bolt I ordered (and didn't use) when I did my FP Gauge...
E-mail me direct:
"fj40_73@hotmail.com"
Dave Alberts
anacortes, WA
thank you, i will need them when i put it back together and I will be sure to pass on the kindness you have given a complete stranger!
I got the washers yesterday and the truck is up and running, i also found a crack in the fuel inlet to the vp-44 so be on the lookout if you get a fuel leak in that area.
Thanks for all the help!
Cool..... got 'em in a timely manner... .
Crack in the VP44... ... is it the Banjo bolt (cuz I gots one of them too if'n ya need it).
Dave
Oh... ok... .
I got the Bajo Bolt when I did the FP Gauge - thought I might need it - but I didn't.
Hope all is well... .
Dave
