A little story about a bad miss at idle and how I fixed it.
Just out of the blue my truck started idling really rough with low RPM, after researching in great detail, here is what I did.
1. Ran two complete tanks of fuel out with triple additive. NO EFFECT
2. Checked my overflow valve spring, it should be . 550, It was . 44 so I stretched it. No difference
3. Installed a fuel pressure gauge. Pressure was 28 lbs at idle.
NO IM REALLY SCRATCHING MY HEAD.
4. Cracked open my lines at the injectors one at a time while idling, AH HAA,, found the number 3 cylinder was dead.
5. To confirm that it was not the injector I switched the #1 and #3 injectors, the #3 stayed dead.
6. I pulled my valve cover off on #3 and checked gap. It was good.
7. Called Al at Piers, he sold me a slightly tweaked rebuilt injector pump and shipped it to FL. “3300 rpm springs, 191d valves, #4 plate, calibrated, etc. ”
8. My new friend/mechanic Todd Struck in Bushnell, FL did the install yesterday and that fixed it. I had him do the KDP at the same time.
If anyone in FL ever needs any work done on any vehicle, especially your Dodge Diesel, I HIGHLY recommend Todd. (352) 568-7591.
BTW. That new pump from Piers Rocks!!!!
Now I need to figure out how to calm down my cruise control, it will give you whiplash at 70 when you engage it.
Many thanks to all that helped.
John Oliverio
John Oliverio
