I have two trucks I ordered at the same time, both 2500's quad cab 6 spd and 4wd. One red and one black, both trucks have about 13k miles on them. The trucks are identical except color. Now my problem, the red truck has all the power I could ever imagine, it could probly yank the winch off my D5 cat. The black truck however is a different story, I don't think it could pull the hat off my head. I have been to the dealer many times only to get the same answer of "come back when you have 20k miles, we can't do anything for that. " My first pull with the black truck was when it had 470 miles on it, I pulled load of round bales of hay and it pulled great. It has been down hill from there! The truck runs great empty.
I tried to pull a tractor and round baler today, and I couldnt get it over 45 mph. I had to run in 5th gear, and here's the weird part. If I put the pedal all the way down, it would howl like a coon dog, then quit. The howl would only last a few seconds then quit for a few seconds then howl again, and so on and so on, until I backed out of the throttle. I talked to my dealer and he acted concerned but knew nothing, I don't know what to do with this truck. THis truck has always been different (noises it makes) last fall I loaded a tractor on a trailer, when I went to take off, the motor made a horrible skreeek and shut down. It had already begun to loose power when it did that or I'd suspect that might have something to do with it.
Sorry its so long I just wanted to provide as much info as I could, if anyone knows or has any ideas I am at a total loss, any help is appreciated.
Thanks
Chad
Thanks
Chad
