Id take the edge box off first if its an EZ,see if that helps,I suspect a big boost leak,check all the hoses and boots,to see if one slipped off partially,you wouldnt believe the power you lose when this happens. Check for intake/exhaust restrictions. I friend of mine had no power,turned out he backed into a snow bank and pinched the exhaust ,resulting in no power. . Id check fuel pressure with a guage,going down the road,stomp the throttl,e ans see where it goes. Anythign under 6-8psi is not good.
