For about 2 months now, my truck tries to dies when idling - sometimes. The ECM keeps it from happening, so when this occurs the engine will lug, then pick up to about 1300RPM, then repeat. At first it only happened when the engine was cold(first started), lately it has become a common occurance and has begun doing it when I take off from a stop sign even when the engine is at temp(sometimes). I have had one Dodge tech tell me that the fuel pump probably has worn and has a sticking valve.
Also, I get more black smoke than I have before. Since I have no mods on my truck, I usually don't smoke at all.
I have 135k on the truck, and they are hard miles, so lots of fuel has gone thru the engine.
I have run power services additive, 2 cycle oil, and now I use Lucas because it gives me better MPG (though it does not seem to effect my problem)
Any input will be appreciated.
