Been out of the buis for a few yrs , so I do not remember the yr to yr changes , but there is a huge differance in the real [ pro ] scanners and what you can get for a couple hundred bucks , but if you not making a living with one then spending $2,000 - 3,000 + , may not be worth it , but I've seen on ebay , $2,500 Snap On scanners for $500 - 600 , its a lot having a computer , the pro. scanners will do so much , it takes some good training & a lot of expreince to use to there full extent .
But get yourself a set of gauges [ fuel pressure ] becouse the newer trucks [ 24 valve ] have a easly damaged main fuel pump , from I've been reading/hearing , the lift pump goes and that shortens the life of your main pump , so keep an eye out & fuel gauge .
